GTA V is very CPU intensive and if your CPU is pinned at 100% the only thing you can do to get more FPS with that CPU is to overclock it, but I doubt that it will give you any significant improvement.
EDIT:
Yes, there is possibility that some settings put more load on CPU at low and more on GPU at higher, so play with it a bit.
https://linustechtips.com/topic/761837-1050ti-low-fps/#findComment-9626684
I have found luck changing the settings and balance between my cpu and gpu. Games ive played have given me the option within my EVGA OCX software to decide what does what amount of load and how fast it runs. I currently Use a FX-8320 with a 1050ti EVGA ssc. I play GTA 5 at 60+ FPS.. CPU usage at 67%, and gpu usage at 45%. Mind you my CPU is stable at 4.4 Ghz, and my Card is stock at 1.4 Ghz Turbo.
https://linustechtips.com/topic/761837-1050ti-low-fps/#findComment-9626754
38 minutes ago, MalfurionStormrage said:
I got a 1050Ti 4gb gddr5 with Quad Q8400 and only 30 fps in GTA V.
yeah of course you are, you are using a 10 years old CPU what did you expect?
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/761837-1050ti-low-fps/#findComment-9626759
Just now, i_build_nanosuits said:
yeah of course you are you are using 10 years old dual core CPU what did you expect?
He's got a point, look into upgrading before you kill it with what im assuming is the stock cooler. Nice build btw @i_build_nanosuits
https://linustechtips.com/topic/761837-1050ti-low-fps/#findComment-9626766
this is definitely not a GPU problem you are having. time to upgrade to a newer cpu
PC: ryzen r7 1700 | Gigabyte GTX 1080 Windforce OC | gskill 16gb ddr4 2666mhz | Asrock AB 350m pro4 mobo | 120gb m.2 ssd, 240gb sata ssd, 2tb 7200rpm hdd | 750W Coolermaster powersupply | Phanteks Eclipse case | monitor: BenQ PD2500Q
https://linustechtips.com/topic/761837-1050ti-low-fps/#findComment-9626776
I play on lowest settings 1080p, only 30 fps in city. gpu usage 30% cpu 100%... but i see others with q8400 50+fps...
Should I put settings higher than low.. 30 fps is really bad...
Your CPU is bottlenecking your GPU.
https://linustechtips.com/topic/761837-1050ti-low-fps/#findComment-9626779
thank you :)
https://linustechtips.com/topic/761837-1050ti-low-fps/#findComment-9626824
