I have a friend that is dead set on getting an Origin SLX and getting the most expensive option in each config option, 'cause it's custom laptop and if it cost more it must be better. I'm looking at the specs and they have a desktop 7700k running at 4.5ghz and is overclockable. As we know the 7700k is a rather hot CPU even with an AIO thanks to the TIM. I'm wondering if the 7700k in the Origin SLX will hit that horrible 100c limit and start to thermal throttle? Also are there any other pitfalls I should let him know about before he blows his money on this?
I spend too much on my PC. Then I spend even more on my Sim Rig. Damn, this stuff's expensive.
https://linustechtips.com/topic/761790-7700k-in-origin-slx/
Well if you buy it from Origin it will hit that horrible 100c because Origin is a shit retailer. Get it here.
http://www.hidevolution.com/evoc-p870km1-dual-gtx-1080.html
Your friend should also know that more expensive options aren't always the best. Example would be like the Killer 1535 wifi card. More expensive than the Intel 8625, way fucking worse.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/761790-7700k-in-origin-slx/#findComment-9627477
1 hour ago, lilbman said:
I don't want to debate and I'm only asking out of curiosity(knowledge is power), but why is it better?
It's just about consistency. You need to run legacy versions of the Killer software to get the 1535 working with no drops 100% of the time. Which is bullshit. Objectively, the Killer 1535 is faster SLIGHTLY, when working properly, but getting it working properly is a pain. Sure, some people have it working fine with no issues with out of the box drivers so good for you, but do a quick google search on Killer 1535 connection dropping and you'll literally see threads since the beginning of the Killer branding. They have 0 clue how to build drivers. 0.
Intel 8265 is almost as fast, and FAR more reliable. Which is good. My AW does still run the 1535 as troubleshoot testing. I reinstall the newest drivers every month or so to see if it is working and when connections drops at any time, I revert back to a legacy driver I have that I've confirmed works at all loads with Killer Doubleshot and other features.
Laptop Main
https://linustechtips.com/topic/761790-7700k-in-origin-slx/#findComment-9630717
I would suggest a Alienware 17 r4 for "most expensive" option. get base then upgrade everything.
http://www.dell.com/ca/p/alienware-17-laptop/pd?oc=na174_fkbl_h14e&model_id=alienware-17-laptop
Alienware 17 R4
Alienware 17 R4
Operating System
Windows 10 Pro 64-bit English
Video Card
NVIDIA® GeForce® GTX 1080 with 8GB GDDR5X
Processor
7th Generation Intel® Core™ i7-7820HK (Quad-Core, 8MB Cache, Overclocking up to 4.4GHz )
Microsoft Application Software
Microsoft Office 30 Day Trial
Security Software Upgrade to 3-Year Subscription for $49.99 Limited Time Offer
No Anti-virus Requested
LCD
Alienware 17.3” QHD (2560x1440) 120Hz TN AG 400-nits w/ NVIDIA G-SYNC and Tobii Eye-tracking
Memory
16GB DDR4 at 2400MHz (2x8GB)
Hard Drive
512GB PCIe SSD (Boot) + 1TB 7200RPM  SATA 6Gb/s (Storage)
Wireless
Killer 1435 802.11ac 2x2 WiFi and Bluetooth 4.1
Primary Battery
Lithium Ion (99 Wh) Battery
AC Adapter
Alienware 330W AC Adapter
Cable
US Power Cord
Keyboard
English Keyboard
Operating System Recovery Options
No OS Recovery Disc Included
FGA Module
No FGA
Systems Management
Kaby Lake Driver
Placemat
Placemat (English,French,BRPT,Spanish)
Packaging
Alienware 17 R3 Shipping Material
Non-Microsoft Application Software
Additional Software
Driver
N1435 & N1535 Wireless Driver
Documentation/Disks
Safety/Environment and Regulatory Guide (English/French)
Retail Software
Dell.com Order
Packing Label
Dell.com Order
Service
4 Years Premium Support
Accidental Damage Service
4 Years Accidental Damage Service
Processor Label
Intel® Core™ i7 Label
What you need to get
RAM
Corsair Vengeance® Series 32GB (2x16GB) DDR4 SODIMM 2666MHz CL18 Memory Kit (CMSX32GX4M2A2666C18)
Wireless
Intel Wireless-AC 8265 NGFF Dual Band 802.11ac 867Mbps WiFi + Bluetooth 4.2 Card
Hard Drive
Samsung 960 PRO 2TB
Samsung 960 PRO 2TB
Samsung 850 EVO 4TB
External GPU
Alienware External GPU
GPU
1080ti (some people water cooled this so its kind of sick)
+ Pay someone to fix it up :) and you are good.
#SLIDoesntWorkOnAllGames
If you are going all out.... GO ALL OUT.
https://linustechtips.com/topic/761790-7700k-in-origin-slx/#findComment-9631580
I never get drops...but just to be sure, that legacy driver is sounding pretty good.  Can you link me to it?
https://linustechtips.com/topic/761790-7700k-in-origin-slx/#findComment-9633102
LOL I want to, but I literally don't have the link anymore. Completely forgot where it is. It's somewhere on NBR Killer 1535 something. I just grabbed it and never looked back.
Laptop Main
https://linustechtips.com/topic/761790-7700k-in-origin-slx/#findComment-9635412
Yeah, don't bother getting it from Origin PC. Please. Get it from HIDevolution.com as @Pendragon linked you. It *WILL* throttle to 100c at stock under relatively light loads from Origin PC. I should know, because I required delidding on mine to get temperatures somewhat bearable and some tweaking to not have to use max fanspeeds on even low end games like DragonQuest Heroes to avoid 85c spikes on my CPU using the "Overclock" fan profile (Auto would be worse as it's a less aggressive fan curve).
From HID he should be capable of at least handling most any load at 4.7GHz using max fans, and most games should be fine as-is.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/761790-7700k-in-origin-slx/#findComment-9637118
