Just now, JDE said:
How come. There is no upgrade path (just like the 1155 path you recommended) and the IPC and preformance is still reasonable for the cost
Really, really temperamental architecture. Needs to be OC'd and gets warm to compete with modern processors. Doesn't need 6 cores. Dying motherboards since the architecture is 7+ years old and they will get more and more scarce as time goes on
idk
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624603
Just now, Ques2.0 said:
I was originally going to do an i3 6100 with the h110 motherboard 8gb or ram and then the gt 740 and once the summer I'll get the gtx 1050ti
oh god, no.. you can get so much more power used and the 1050Ti is a shit card
idk
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624608
Go for the RX 470 instead. Much better for price.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624609
1 minute ago, Ques2.0 said:
So the i3 6100 is a good choice but the gtx 1050ti is boo boo?
i3 6100 and 1050 Ti is both boo boo. I would go with i7 2700 and RX 470.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624630
4 minutes ago, Ques2.0 said:
I can buy both on eBay? And does this CPU have an upgrade path
i7? No. But you don't really need a upgrade path at this point because AMD Ryzen looks like it will be a good value. That is the only advantage of the i3. You have upgrade path all the way to Kaby Lake i7.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624689
For the buying on ebay: i7 YES RX 470 NO (yes but not really because its kinda new)
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624694
the only problem is you end up with a bottom range i3 that will loose so much value to sell and upgrade. Don't get me wrong I like your thinking here but for a budget kind of build it just doesn't seem worth it.
@OP you been able to find any 4th gen i5's  ? something like a 4460 could work great for you, will last long time for gaming long as you go bigger on the GPU
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624700
O yeah forgot about Haswell existing... Somehow using a haswell to type this yet can't remember it existing...
The i3 has a upgrade path but little resale value. Another disadvantage.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624709
2 minutes ago, Ques2.0 said:
If I get the i5 4460 could I upgrade in the future
Yes to a i7 4770 or 4790
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624740
So what is the best option so I can upgrade later
https://linustechtips.com/topic/761675-pc-parts/page/2/#findComment-9624745
