Just now, Ques2.0 said:
Just gaming
In that case, there should be several people here with pre-designed $400 gaming rigs who will likely post shortly. :D
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624497
I suggest looking at people like techsource and others who do monthly budget builds. Plenty of them do $400 builds or around there. What I like about these videos is that they built it, explain, and test it in a short time period.
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624501
3 minutes ago, Ques2.0 said:
Thanks, a friend is giving me his old gt 740 so I won't need the gpu I was going to use that one until the summer, just a budget pc build that can run bf1 smoothly doesn't have to be at 1080p ultra settings just need an entry level system
with that gt 740 its more like 720p low @ 30fps
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624517
Would the i5 match with the old gt 740
never, more like a celeron from last year
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624523
Ahh I see but they are quad core which is key. Would his i7 2600 last me for a year or so with new titles releases this year
maybe 2 or 3 years. Yet it is from 2012/2013 era.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624554
The main problem is the GPU. Skylake Celeron/Pentium would saturate it completely. The CPU is no problem but the GPU is.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624562
I made this before seeing you wanted to go the used route, but I'm going to post it anyway:
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($59.99 @ SuperBiiz)
Motherboard: ASRock B250M-HDV Micro ATX LGA1151 Motherboard  ($61.98 @ Newegg)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($52.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: EVGA GeForce GTX 1050 2GB ACX 2.0 Video Card  ($106.99 @ SuperBiiz)
Case: DIYPC DIY-F2-W ATX Mini Tower Case  ($39.98 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($47.89 @ B&H)
Total: $418.71
Generated by PCPartPicker 2017-04-03 22:27 EDT-0400
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624566
Total: $418.71
Only problem is the pentium 7th generation are out of stock everywhere
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624574
So I am thinking:
i7 2700/3770
8GB RAM
H6x for 2700 or H/B7X for 3770
HD 7950
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624579
Or what about the X5650 route. That seems to be a good path right now.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624582
Just now, Droidbot said:
He's upgrading the GPU, and I wouldn't recommend X58 for anything in 2017
How come. There is no upgrade path (just like the 1155 path you recommended) and the IPC and preformance is still reasonable for the cost
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/761675-pc-parts/#findComment-9624594
