So i’m resurrecting my old computer and i’m considering using my old HDD (7-ish yrs old), it has been making noises for a few years now but after getting a new computer i never knew HDD's were quiet, and now the noise is concerning me. I'll provide a video of me transferring files over to the new computer.
https://linustechtips.com/topic/760790-keep-old-hhd/
sounds like a 7 year old HDD to me...
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/760790-keep-old-hhd/#findComment-9614706
You're copying 12,000 files or so (I can't read that number for sure, but it was 11,xxx).  Lots of seeking is perfectly normal.  A defrag might help matters if you want to speed it up.  But other than that, I don't hear any noises that are abnormal on that recording.  Yeah, check the SMART data using smartctl/smartmontools or CrystalDiskInfo, but those noises are perfectly normal 'seeking' noises associated with copying large numbers of small files.
https://linustechtips.com/topic/760790-keep-old-hhd/#findComment-9614749
correction it was 513,xxx
20 minutes ago, Electronics Wizardy said:
Check the smart data on the drive with something like crystal disk info
Crystal says it's “good” with 1.5yrs of Power On Hours
Thank you two for the help i'm glad that the noises are not the harbinger of death for my HDD.
https://linustechtips.com/topic/760790-keep-old-hhd/#findComment-9614789
but you don't know when it will die. Make sure you have backups
https://linustechtips.com/topic/760790-keep-old-hhd/#findComment-9614798
