Headphone burn in?
Go to solution Solved by Guest,
NO.
I've recently ordered the "Audio-Technica ath-m40x" and I was wondering if burning in your headphones was actually needed since I've seen many audiophiles burn in their headphones before using them.
Is it true you need to burn in your headphones for optimal sound quality?
https://linustechtips.com/topic/760616-headphone-burn-in/
You need to burn them in to ensure that the piston rings gain proper fitment, the gears lubr... Oh, headphones!
No.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/760616-headphone-burn-in/#findComment-9612813
16 minutes ago, Just-Chill said:
'Headphone burn in?'
Those are some words I never thought I would see in the same sentence. Audiophiles are crazy.
It's when you play different types of music through your new audio equipment to loosen up the drivers "for better quality". Many people believe it works but most people say it's false.
https://linustechtips.com/topic/760616-headphone-burn-in/#findComment-9613015
