the compatibility issue is that you selected a Z170 motherboard, and might need to update the BIOS to have it work with your 7th gen chip.
if you want plug & play functionality you might want to switch to a Z270 motherboard.
updating the BIOS shouldn't be too hard though.
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9607826
Which is impossible if the BIOS is pre-KL bios (2202 i think).
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9607889
fair point.
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9607953
10 minutes ago, Samuel Jones said:
@knightslugger @RollinLower what do I do then?
please, don't get that power supply, it's garbage and can very likely set your parts on fire.
https://www.theregister.co.uk/2012/11/26/exploding_computer_vs_reg_reader/
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9610203
9 hours ago, Samuel Jones said:
https://pcpartpicker.com/list/pJy7gL
What compatibility problems are there and what else do I need to select to complete this build?
A psu is the only part that can destroy every other component in a system. Surely it is worth investing in a unit that will instead provide stable, clean power to those components. Leading longer component lifetimes and fewer unexplained glitches.
I would suggest foregoing an overclocking system. The money saved can be better spent on other parts of the system.
An optical drive is generally not needed these days. Unless one had a CD/DVD collection.
Without knowing how the system is to be used or the budget it is a bit difficult to flesh out the build. But something like the following would be a decent general and gaming system. It lacks an o/s and peripherals.
CPU: Intel Core i5-7600 3.5GHz Quad-Core Processor  ($209.99 @ SuperBiiz)
Motherboard: Asus PRIME B250-PLUS ATX LGA1151 Motherboard  ($99.00 @ B&H)
Memory: G.Skill NT Series 8GB (2 x 4GB) DDR4-2400 Memory  ($57.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($92.89 @ OutletPC)
Video Card: Gigabyte Radeon RX 480 8GB Video Card  ($239.99 @ SuperBiiz)
Case: BitFenix Nova ATX Mid Tower Case  ($29.99 @ NCIX US)
Power Supply: SeaSonic 360W 80+ Gold Certified ATX Power Supply  ($57.99 @ SuperBiiz)
Optical Drive: LG GH24NSC0B DVD/CD Writer  ($16.88 @ OutletPC)
Total: $804.72
Generated by PCPartPicker 2017-04-01 01:09 EDT-0400
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9610322
get a z270 board.
System specs:
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9610360
Total: $804.72
360w might not be a good choice. 500 would be better suited for efficincy.
System specs:
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9610370
Just now, Samuel Jones said:
@knightslugger can u oc on a z270?
yes.
System specs:
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9610375
47 minutes ago, Samuel Jones said:
@brob under $1000 and preferably under $700. Any screen that's acceptable will do.
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor  ($294.99 @ SuperBiiz)
Motherboard: ASRock B150M-HDS Micro ATX LGA1151 Motherboard  ($41.98 @ Newegg) find out if the bios supports kabylake or get an i7 6700/b250 mobo.
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($99.99 @ Newegg)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive  ($81.99 @ B&H)
Video Card: Gigabyte GeForce GTX 1050 2GB OC Video Card  ($99.99 @ Amazon)
Case: VIVO CASE-V06 MicroATX Mid Tower Case  ($33.99 @ Jet)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($47.89 @ B&H)
Monitor: AOC I2269VW 21.5" 1920x1080 60Hz Monitor  ($79.99 @ Best Buy)
Total: $780.81
Generated by PCPartPicker 2017-04-01 02:12 EDT-0400
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9610526
20 hours ago, Samuel Jones said:
@knightslugger do I need sli support if I plan to buy a graphics card in the future?
only if you think you might buy and use two nvidea pascal cards in the future. if you buy an AMD, crossfire will work on either B350 or X370. But for right now SLI is only supported on the X370s.
System specs:
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9614299
On 4/2/2017 at 7:07 AM, Samuel Jones said:
@knightslugger nah ill problably buy 1 good graphics card
Then you can get a b350 board if you like.
System specs:
https://linustechtips.com/topic/760179-pc-part-problems/#findComment-9620339
