Hi all,
Putting together my first build, and this is what I have come up with so far. Would love to get some feed back regarding any changes/improvements I can make while staying around my budget of 900$ USD
Cpu - AMD FX-6300
gpu - Gigabyte GeForce GTX 1070
Motherbord - MSI 970 Gaming AMD AM3 GBE LAN ATX Motherboard
Ram - Kingston ValueRAM Server Premier - DDR3 - 8 GB - DIMM 240-pin - 1600 MHz
Storage - Kingston ssdnow 240g
Psw - WITH CASE
Case - Cooler Master Elite 350
https://linustechtips.com/topic/758881-my-first-pc-build/
1 minute ago, niksaka said:
Hi all,
Cpu - AMD FX-6300
Psw - WITH CASE
Don't get any FX series CPUs to start. Also use pcpartpicker.com. What are you using this computer for?
https://linustechtips.com/topic/758881-my-first-pc-build/#findComment-9591115
AMD FX CPUs are horrible. Don't get them.
Get an i5 7500 + RX480 or GTX 1070.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/758881-my-first-pc-build/#findComment-9591143
1 minute ago, Damascus said:
Check this out, miles better CPU
https://pcpartpicker.com/list/KLFKbj
Just wondering, What's that parametric filter thing you're using on PC partpicker.
seems like it picks the cheapest product matching the filter requirements, right? how do I use that, because it seems really useful.
Laptop:
https://linustechtips.com/topic/758881-my-first-pc-build/#findComment-9591151
To game mostly
That 6300 is 5 years old, don't get it
http://cpu.userbenchmark.com/Compare/AMD-Ryzen-7-1700-vs-AMD-FX-6300/3917vs1555
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/758881-my-first-pc-build/#findComment-9591152
Just now, cmprinho said:
yeah grab a ryzen 7 1700 and push it up to 4ghz - you will have more horsepower than a stock 1800X way better :)
Despite what you have heard, a 4Ghz overclock on the 1700 is not guaranteed, and you shouldn't be recommending that to someone who you aren't sure knows how to overclock.
Laptop:
https://linustechtips.com/topic/758881-my-first-pc-build/#findComment-9591168
Just now, Damascus said:
Set the GPU or whatever component, choose cheapest and ad from filter
~snip~
Thanks Man!!
Laptop:
https://linustechtips.com/topic/758881-my-first-pc-build/#findComment-9591169
Well even if you dont overclock - 66% of the price for 90 - 95% of the 1800x frames seems worth it
https://linustechtips.com/topic/758881-my-first-pc-build/#findComment-9591178
PCPartPicker part list: https://pcpartpicker.com/list/ZYRgNN
Price breakdown by merchant: https://pcpartpicker.com/list/ZYRgNN/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($292.49 @ SuperBiiz)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($44.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2666 Memory  ($52.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($379.00 @ Jet)
Case: Xion XON-310_BK MicroATX Mid Tower Case  ($22.99 @ Amazon)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.90 @ Amazon)
Total: $896.25
Generated by PCPartPicker 2017-03-28 13:11 EDT-0400
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/758881-my-first-pc-build/#findComment-9591188
