So, i have been having some problems lately?
1. i only get 500k speeds most of the time
2. my internet goes out and then turns on randomly
3. i have this asus moden BUT it for some reason has very slow speeds
Does anyone know how to fix this?
Best of myself(1000th post)
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Cooler Master masterbox lite 3.1
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Dell precision t3400 motherboard
https://linustechtips.com/topic/758560-internet-problems/
You contacted ISP?
-- BSOD : ( --
https://linustechtips.com/topic/758560-internet-problems/#findComment-9587599
1 minute ago, COUPER MILLAR said:
We need more info. Expected speeds, WiFi or hard line, number of concurrent user, what type of connection (dsl, cable, fiber). Modem and router models.
ISP Centruty link suspected plan 1MB/s
WIFI 2GHz isp router (because ASUS doesnt work)
Devices 6-8
DSL
Century tel router/modem
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
https://linustechtips.com/topic/758560-internet-problems/#findComment-9587619
Devices 6-8
DSL
Do you notice specific times of day that you have the drops? My assumption is that you are on a dsl line that will fluctuate with network congestion. Also do you live in a congested area with multiple WiFi networks? You may be having an issue with signal interference.
Has the asus router recently stopped working and now you are having problems, or has it never worked?
https://linustechtips.com/topic/758560-internet-problems/#findComment-9587630
it has worked, just now i set it to access point mode and when i try to connect to it i get this
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
https://linustechtips.com/topic/758560-internet-problems/#findComment-9587650
Just now, Spenser1337 said:
1mbps in 2017
2 words
Cheap Parents
But were moving soon and i get to pick the isp :D
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
https://linustechtips.com/topic/758560-internet-problems/#findComment-9587731
2 minutes ago, System32 said:
What!? Do you live in a flop house?????
nope
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
https://linustechtips.com/topic/758560-internet-problems/#findComment-9587785
when you set it to AP mode it no longer assigns IP addresses, instead IP addresses will be assigned by your ISP provided router. Depending on your comfort with networking, you can either pull up the active DHCP leases on your ISP router and figure out what IP the ASUS router has been assigned, or i believe asus has a tool you can download that will help you determine the new IP address. Once you have the ASUS IP all you do is enter that into a browser, for example 192.168.1.85 instead of the 192.168.1.1 you would enter normally. From there you should be able to configure the router to function properly as an AP and avoid further issues.
Are you connection the ASUS router to the ISP router via ethernet or are you trying to use it as a wifi bridged AP? The latter will be more complicated and wont resolve the issue of the poor performance of the ISP router.
If none of this works there is also a way to set the router to a specific IP address prior to setting it up as a AP, again this is a bit more complicated but i could walk you through, possibly even with screen shots as i also have a coupe asus routers that would have similar interfaces.
https://linustechtips.com/topic/758560-internet-problems/#findComment-9587821
I would suggest when you move to stay away from DSL. Its a dead technology it just doesnt know it yet. Try to go for a cable or fiber connection. While I they bend you over and fuck you every month with their bill, Comcast has mostly a solid network. They just like to raise fees.
https://linustechtips.com/topic/758560-internet-problems/#findComment-9599547
