Just wanted ask if anyone has tested this as I'm waiting for my graphics card to arrive I am using intel onboard graphics in my 7700k.
Is there a performance difference between the same 7700k using onboard graphics and using a descrete card?
Would temps be different at the same settings. Can you overclock more when the cpu isn't doing the video?
If no one has I may look at this and post what I find once my gpu arrives and I can make the comparison.
https://linustechtips.com/topic/758364-7700k-temps-and-intel-graphics/
What is your purpose for the computer? if you want to game you'll need at least a 1060 6gb or better so this great processor isn't wasted, the Intel HD 630 is not bad and is enough compared to useless GT cards but then again if you already spent so much on the CPU why not pair it with a good GPU for balancing purpose?
Personal Desktop":
Luna, the temporary Desktop:
1 minute ago, Princess Cadence said:
What is your purpose for the computer? if you want to game you'll need at least a 1060 or better so this great processor isn't wasted, the HD 630 is not bad and is enough compared to useless GT cards but then again if you already spent so much on the CPU why not pair it with a good GPU for balancing purpose?
V V V
Op: There shouldn't be any noticeable performance differences.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
I've been using onboard graphics with it OCd to 5.2 GHz while waiting for my replacement waterpump and havent had any problems. If you mean performance as far as gaming or video editing, yes. Yes there is a big performance difference.
I did have problems before I installed all of the latest updates using integrated graphics.
Just now, bgibbz said:
V V V
Personal Desktop":
As far as CPU performance alone, no.  It will perform the same with the iGPU on or off.
Temps will be roughly the same, maybe a couple/few degrees warmer.  No biggie.
Sounds like you've got a nice chip.
I think you misunderstood op, he was asking if using iGPU makes the CPU perform worse.
And you misunderstood me, the matter I addressed to was mostly that a "discrete" which I'd believe to be a low end GPU is probably not worthy pairing for such a high end CPU with a capable on board already, if he can return the card he is waiting for say it is a 750ti level card, it'd be for the best.
Personal Desktop":
Discrete simply means a dedicated gpu, Gtx 1080ti is a discrete gpu.
Really now? I'd use the dedicated word rather... well I apologize, just a language miss understanding.
Personal Desktop":
7700k is all about the delid.
