An ethernet cable?
My system:
CPU: i5-6600K <> Mobo: Gigabyte Z270X Ultra Gaming <> Cooling: Noctua NH-D15 <> GPU: Gigabyte GTX 1070 G1 <> SSD: Intel 600p 256Gb
RAM: Corsair Vengeance LPX (16Gb @ 3000Mhz) <> PSU: Seasonic M12II EVO 620W <> Case: Corsair Carbide 400C <> Fans: 6x Bitfenix Spectre
  Monitor: Asus VG248QE <> Mouse: Steelseries Rival 300 <> Keyboard: Gamdias Hermes Ultimate <> Speakers: Logitech Z333
Ok, my cheapo Bitfenix fans are 120mm, all six of them. Are you happy now?
I am not actually Linus...
You can leave my signature now.....
https://linustechtips.com/topic/757057-help/#findComment-9571642
Just now, Kloaked said:
What is an Ethernet cable? Does it come with WiFi and LTE?
someone pass the bleach
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/757057-help/#findComment-9571703
2 minutes ago, Damascus said:
a usb wifi adapter is a budget option
I don't think that usb wifi is worth it when there are cheap great pci-e 1x and pci solutions, in his case all he needs probably is a TP-LINK 150mbps pci-e 1x wifi card and he is good to go
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/757057-help/#findComment-9571719
Probably but its good to have all the options on the table
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/757057-help/#findComment-9571742
