R9 Fury Nitro is the best for that price, depending on what country you live in.
Otherwise it would be the 1060/480. Or a used 980 TI (rare for less than $300).
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
If you have a seriously good 500 watt psu (this is cutting it pretty close), a good 550 watt psu, a decent 600 watt psu, or better go with an r9 fury... if this deal is available where you live:
https://www.newegg.com/Product/Product.aspx?Item=N82E16814202186&cm_re=r9_fury-_-14-202-186-_-Product
Also make sure this card fits in your case, it may be a close call.
Edited by ATFink
Possible case restriction
CPU: i7 4790k @ 4.7 GHz
GPU: XFX GTS RX580 4GB
Cooling: Corsair h100i
Mobo: Asus z97-A
RAM: 4x8 GB 1600 MHz Corsair Vengence
PSU: Corsair HX850
Case: NZXT S340 Elite Tempered glass edition
Display: LG 29UM68-P
Keyboard: Roccat Ryos MK FX RGB
Mouse: Logitech g900 Chaos Spectrum
Headphones: Sennheiser HD6XX
OS: Windows 10 Home
8 minutes ago, AMD X INTEL X NVIDIA said:
no more recommendations??
You asked what GPU, you have been told the best one for your money at under $300. Obviously there is a whole tonne below $300
1050 < 1050ti < AMD 470 < 970  < 1060 3gb < 980 < 1060 6gb ~ 480 4gb/8gb < Fury < Fury X > 980ti
you will be very lucky to find a Fury X or 980ti for under $300
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
New card : RX 480 4GB is the best in terms of price/perf and often around 200$. Stay away from the GTX 1060 3GB though, it's usually a terrible bargain, and 3GB of VRAM is short for 1080p.
Used card : Fury X or 980 Ti for around 300$ would be awesome but like other said, pretty rare at that price
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
