Help me!
I get graphical glitches in all games. It started when i took my gpu out to resit them and the crossfire bridge as i noticed that crossfire wasnt working. Well anyway since then i have been getting weird glitches in different games. Mostly, in ARMA 3 the terrain flickers and if i go first person in any vehicle i get really weird audio glitches and my game stutters and i get screen tearing (even tho i don't get above 25-30 fps)
In other games where i am locked to 60fps i get tons of screen tearing and stuttering
CPU: AMD-FX8350
GPU: Readon HD 7850 x2
MOBO: Asus Sabertooth 990fx r.2
RAM: 32gb (kingston?) ddr3 @ 1866mhz
https://linustechtips.com/topic/756594-graphics-card-issues/
Potential scaling issues?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/756594-graphics-card-issues/#findComment-9566040
Just now, Jason1232 said:
What do you mean by that?
Crossfire doesn't always work properly
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/756594-graphics-card-issues/#findComment-9566048
I should also add i get the issue even when i disable crossfire
Try using DDU to uninstall drivers, then get the newest drivers here: http://support.amd.com/en-us/download
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/756594-graphics-card-issues/#findComment-9566071
I have reinstalled drivers like 3 times
You should mention everything in your post. It might just be that its defective. Or it could be what happened to Linus in SC3, the power supply was too crappy.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/756594-graphics-card-issues/#findComment-9566087
25 minutes ago, Jason1232 said:
Help me!
CPU: AMD-FX8350
Might just be your cards that are defect but to check, do you get the same artifacting in Furmark?
Had my HD 7850 die 1 year ago because of age also had lots of artifacting issues.
And it might not be be artifacting so you mentioned tearing, what refresh rate is your monitor?
The FX-8350 btw is pretty old now and stuttering is honestly something you can expect in some games with that CPU and crossfire. The CPU didn't age well...
EDIT: Do you get any artifacting on your desktop?
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/756594-graphics-card-issues/#findComment-9566147
tried with this, still no change :c
maby it is defective pull of the 2nd card insert it in the first ones slot and test
if it works try adding the second as crossfire and it id doesnt but the other one works youre left with 1
sorry
https://linustechtips.com/topic/756594-graphics-card-issues/#findComment-9566148
sorry
i restarted with just on card installed and this cam up when i tried to open the graphics drivers: 97757e5793.png
https://linustechtips.com/topic/756594-graphics-card-issues/#findComment-9566225
