Hi i need help i have tried to build my first 2 computers on to different price points. 1800usd and 1480usd. I'm from sweden so i would be grateful if you would keep that in mind and i need help to see if everything works and is up to the new generation.
1800usd computer in swedish money 16000kr
NZXT noctis 450 midi tower vit
 Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
intel core i7-7700k kaby lake processor
 ASUS Prime Z270-P, Socket-1151
hyperx fury 240gb 2.5 ssd
seagate firecuda 1tb 3.5 sshd
corsair cx650m, 650w psu
noctua nh-d15 cpu cooler
msi geforce gtx 1070 armor oc
1480usd computer in swedish money 13000kr
evga geforce gtx 980 ti 6gb -demo
corsair vengeance lpx ddr4 3000mhz 16gb
intel core i5-7600k kaby lake processor
asus strix z270h gaming, socket-1151
hyperx fury 120gb 2.5 ssd
 seagate Barracuda 2tb 3.5 hdd
and need a cheap fan!!
I have heard a lot about the new ryzen 7 generation is that anything i should watch out for?
I will mostly be using this computer for gaming and i have everything else and only need the computer.
I got the prices from komplett
https://linustechtips.com/topic/756583-building-my-first-computer-and-need-help/
As @UberGamerKing said, if you're getting an i7-7700 or i5-7600, get a Z270 board. Z170 boards are compatible only after a BIOS update, which you can't do if you don't have a compatible CPU installed.
Also to add what they said, figure out what motherboard features you need and get the cheapest thing that fits that. Motherboards don't add performance, only connectivity. So spending $250USD Z270 on a motherboard makes no real difference in performance or anything than a $120USD Z270 board.
Ryzen 7 is what I would call more suited for multithreaded workloads. This doesn't mean its bad, but it would be better for stuff like video rendering or having 172 tabs of Chrome open.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Corsair Vengeance LPX is a better option for the ram. faster and cheaper as well.
PC: ryzen r7 1700 | Gigabyte GTX 1080 Windforce OC | gskill 16gb ddr4 2666mhz | Asrock AB 350m pro4 mobo | 120gb m.2 ssd, 240gb sata ssd, 2tb 7200rpm hdd | 750W Coolermaster powersupply | Phanteks Eclipse case | monitor: BenQ PD2500Q
4 minutes ago, Leo sten said:
so an ASUS Prime Z270-P, Socket-1151 would work fine?
yes it would. although be aware that that board does not have SLI support.
and only has 4  sata 6gb/s headers
Just now, Leo sten said:
i'm not that good with computers what is an sli support?
SLI allows you to run two get an additional graphics card, and have them share the workload.
2 minutes ago, deXxterlab97 said:
Only NVIDIA cards
which he is using.
21 minutes ago, deXxterlab97 said:
You can.
Well, with the caveat that it's not a standard feature. :P
But I'd rather have OP get a motherboard with the features they want and compatibility right out of the box. It makes things easier that way.
Yeah and only high end boards have those features. Even something popular like Asus Z170-A doesn't
I would say they should make a standard feature, but how often do you need to update BIOS without a CPU?
The cost of making an extra BIOS update button is expensive I guess
And besides if you need to you only do it once
20 hours ago, deXxterlab97 said:
It will work nicely
@M.Yurizaki
@deXxterlab97 is there anything else i need to fix i changed some things in the main post or do i need to fix stuff on the other computer to? I also don't know anything about storage components like sshd or 1tb hdd so i would be glad if looked it up
Get a hdd and a ssd. Don't get sshd
Ok i Will change that and Will the whole computer be completed after that? Will It work with any ssd and hdd. Should i look for the cheapest ssd and hdd for the most storage? Will the computer run and be Done after that? @deXxterlab97 @M.Yurizaki
18 hours ago, Leo sten said:
@M.Yurizaki
Yes, yes, maybe, and yes.
The maybe part is don't get any cheapo SSD. That goes about as good as you'd expect. If I were to make a suggestion, SanDisk and Kingston both make good budget SSDs.
20 hours ago, Leo sten said:
@M.Yurizaki
I don't see anything else that needs to be changed other than what's been said.
@M.Yurizaki I choosed a Seagate Barracuda 2TB 3.5'' HDD and a Kingston SSDNow KC400 256GB 2.5" SSD would they be a good choice?
Yeah that should be fine.
