3.6 BILLION GB/S DOWNLOAD SPEED, THANKS DSL!
Solved by Evanair,
I'm questioning the "Answered"-ness of this threat. OP said he had ATT DSL, so why is the answer a CABLE MODEM?!?
If it's DSL, look at the line attenuation numbers and dB numbers compared to how far you are from the junction box. A lot of times ATT oversells their service, with the bandwidth getting crosstalk on old lines. You have to prove it to them from their own numbers and math, but they WILL replace the lines if you can prove it's physically impossible for them to give you 45mbps over the older twisted pair lines..
Here's a good place to start.
http://www.speedguide.net/dsl_speed_calc.php
https://www.amazon.com/NETGEAR-Nighthawk-AC1900-Router-CenturyLink/dp/B01BG8AOH8
