Hi,
was putting together he plan for my pc build
https://uk.pcpartpicker.com/list/NVKWwV
is the plan
Keeps saying something about it possibly not fitting in the case - Can someone check this out for me?
What are your thoughts about the build parts in general
EDIT: Changed Cooler to H7
https://linustechtips.com/topic/756297-help-potential-incompatibility/
Any reason you're going for a LP cooler?
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
Just now, lee32uk said:
Change the cooler to something like the Cryorig H7. If you need that much HDD space then a single 6TB works out a bit cheaper. Also no SSD ?
https://uk.pcpartpicker.com/product/j4PzK8/seagate-ironwolf-6tb-35-7200rpm-internal-hard-drive-st6000vn0041
Wanted to recommend/ask the same thing too. No SSD?
Just now, Cyqix said:
Yes. I have no idea on half of what I'm doing
I understand that feeling. A Hyper 212 evo would be better and quieter.
I'm planning to duel boot - How would I run both mac and windows off one SSD & then store data on HDD
You would just put two partitions on the SSD.
Again. No idea how - Don't want to break something before I've even used the PC
Multiple Partitions:
http://plugable.com/2014/09/09/plugable-tech-tips-how-to-partition-and-format-a-new-hard-drive-or-ssd/
At the end, just make each one half the total size.
Dual booting Mac and Windows:
