so my stick of silver 5 has run out after swapping my i3 out of an i7 and im going to need a new stick of thermal paste. what are the recommended pastes?
CPU-I7 4790
COOLER-Be Quiet Pure Rock Slim
MOBO-Gigabyte Z97 HD3
RAM-8GB G.skill Ripjaws X
GPU-Gigabyte GTX 1060 6GB G1 Gaming
SSD-Kingston SSDnow 240GB
HDD-Segate Barracuda 1TB
PSU-Zalman ZM 550w Goldrock Semi-Modular psu
CHASSIS-ThermalTake Core X31
https://linustechtips.com/topic/755931-best-thermal-paste/
I like MX-4, but NT-H1, IC diamond, gelid, thermal grizzly etc.. are good too.
TBH there is no significant difference between any of them.
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558732
yeah ive seen reviews of thermal paste thats why i got silver 5 in the first place cause of the stability but ic diamond and mx4 seem to get better temps so im kinda stuck on what to get.
CPU-I7 4790
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558745
Are you gonna be OCing a lot?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558769
well i have a locked cpu and no intention of cracking open my gpu so no. just after lower temps for more longevity.
CPU-I7 4790
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558775
TBH those few degrees won't impact CPU longevity in any meaningful way, and by the time it does, you'll probably have already upgraded.
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558783
might get a new rig with oc and need some thermal paste just want some just in case you know.
CPU-I7 4790
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558796
for a locked CPU, any normal thermal paste will work.
if you want the absolute best, get what people here have recommended, but don't waste it on a locked CPU.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558843
I have been  using IC Diamond now for the past 7 years and love it. Here is a video that is testing a ton of different pastes I found with a quick google search. I have not watched the video personally as my ISP has a massive fiber outage in my area so I am only getting about 1-3 Mbps down instead of my usual 60 so no bandwidth to watch it right now without stuttering and buffering constantly.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558861
Lol 1-3mbps is good where i live.
CPU-I7 4790
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558934
Yea, it sucks for me lol... they had 3 100gig core links go down from a bad network card as well as 2 of the 3 were cut because someone was digging without getting lines marked from the proper authorities...
Community Standards
"Beast Mode"
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558955
what an idiot. sad thing for me a city which is only 40ks down the road gets 1gig download while the rural areas only get 1-3megs at exorbitant prices
CPU-I7 4790
https://linustechtips.com/topic/755931-best-thermal-paste/#findComment-9558962
