are running intergrated graphics or something
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/754518-gta-5-low-fps/#findComment-9543023
1 hour ago, KikkertjeK said:
i just got my new pc and i tried to run gta 5 but when i started it up i only got like 10 fps with everything on normal settings.
my specs are:
Asus GTX 1060 6gb turbo
intel core i5 7500
8gb ram
Try validating game data
Try changing the settings in geforce experience
Try changing the resolution
Check in geforce experience if your gpu is even connected.
Good luck
https://linustechtips.com/topic/754518-gta-5-low-fps/#findComment-9543138
You should be pulling bare minimum 60-70 fps most of the time with that setup at a mix of very high to ultra settings. I mean that's what I get with my GTX 970 and two cores on my Xeon E3-1231v3 disabled to simulate a 3.8 GHz Haswell i3 (with all cores active on my Xeon it's more like 85-95 fps). Are you sure you don't have your monitor plugged into the motherboard instead of the gpu? Because 10 fps at 1080p sounds like the performance to expect out of integrated graphics.
https://linustechtips.com/topic/754518-gta-5-low-fps/#findComment-9543529
