Get 2 just in case, sometimes you need extra if there's a leak or it gets coloured and needs replacing.
My loop has 3 reservoirs, 360 and 420mm rads, 2 GPUs and a CPU and it took about 1.2 litres give or take. I always prefer to over-estimate as it is useful to have spare fluid to cover leaks and the inevitable level drop after a week or so once the air is out of the system.
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
