Hey guys, a family member needs a good printer that would scan fast and wouldn't be expensive to refill. I have a printer myself that I used years ago for school, but the ink doesn't last very long, also, it won't print in black and white as the other color cartridges are empty :P So, how exactly does a laser printer work? Would it be cheaper to run?
Many thanks, Bruno.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/751895-printing-solution/
Laser printers are MUCH cheaper to run.  While the toner cartridges are generally more expensive they last for thousands of pages instead of hundreds.  Also they are a dry powder instead of a wet ink that can dry out if it isn't used often enough.  I can't tell you how many times I'd go to use my printer that I haven't used in awhile and the ink cartridges would be completely dried out.
Malo Periculosam Libertatem Quam Quietum Servitium
https://linustechtips.com/topic/751895-printing-solution/#findComment-9514694
Like above. Laser printers have higher cost for device and cartridges, but you can print much more so price per page is cheaper. They are also quieter and generally same speed with ink printers.
Quick check on local pricings show that color AIO laser printers are around €300-400, while AIO BW's are half price, same with just color lasers. Ofc for €350 you get wifi, nfc etc. But its still pretty steep initial cost compared to ink competition with €100 stating prices (I paid €150 for mine 9 years ago).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/751895-printing-solution/#findComment-9516965
Laser printers are as fast as an ink printer? what? My school uses laser printers, and they're much faster than the ink printer I have at home :S
https://linustechtips.com/topic/751895-printing-solution/#findComment-9517920
I haven't seen reviews for awhile so that was from memory and 5 years ago. So don't believe everything they say in random forums.
https://linustechtips.com/topic/751895-printing-solution/#findComment-9518016
