Add fan worth it?
Go to solution Solved by nobiggieBIG,
Just now, Walt said:
Do you think adding a fan will be worth it? The fan is 25 euro in my country.
depends on your cooling performance as of current
Hi everyone,
I was just wondering if it's worth it to add another fan to the Cryorig H7? Does it cool better?
And also any ideas of replacing the stock fan with? Or is the stock fan the best?
Thanks!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/751615-add-fan-worth-it/
5 minutes ago, Walt said:
Hi everyone,
Thanks!
Keep the stock fan and add another, make sure its push/pull
A8-7600 {} Gigabyte FM2+ Board {} CX430 {} Corsair Vengeance LP 8gb {} MSI GTX 760 2GB {}
Console.WriteLine("C# is aids");
https://linustechtips.com/topic/751615-add-fan-worth-it/#findComment-9511204
Any tips for which fan to add?
https://linustechtips.com/topic/751615-add-fan-worth-it/#findComment-9511206
22 minutes ago, nobiggieBIG said:
Noctua NF-F12
https://linustechtips.com/topic/751615-add-fan-worth-it/#findComment-9511308
https://linustechtips.com/topic/751615-add-fan-worth-it/#findComment-9511313
Adding another fan won't make much of a difference in performance--maybe 1-2c. It can make up for performance lost from very low fan speeds though.
https://linustechtips.com/topic/751615-add-fan-worth-it/#findComment-9513197
