M.2 Fan?
Go to solution Solved by roylapoutre,
14 minutes ago, mynhierc said:
Can you link to the heatsinks you have? I've searched but I can't find anything I feel is correct.
Tried both this : https://www.amazon.com/Mudder-Aluminum-Heatsink-Cooling-Raspberry/dp/B01LXWK626/ref=sr_1_1?ie=UTF8&qid=1489360625&sr=8-1-spons&keywords=heatsink&psc=1
and this : https://www.amazon.com/Enokay-Cooling-Heatsink-Raspberry-Heatsinks/dp/B014KKY3KI/ref=sr_1_13?ie=UTF8&qid=1489360625&sr=8-13&keywords=heatsink
They perform about the same (even though I expected copper to be a bit more effective)
I've heard of several people using a fan on their M.2 drives. Jerry from Barnaclues Nerdgasm has a heat sink on his from pudget systems with a fan pointed at it, Asus has a file to 3D print a fan holder, the video Linus just released shows the Dell XPS 27 with one.
My question is, should I get one for my M.2?
What kind of fan?
How should it be mounted?
https://linustechtips.com/topic/751409-m2-fan/
I'd say the fan is quite overkill for an M.2 drive. I currently have a 512GB M.2 SSD in my rig, and I simply put 2 heatsinks I had left from my Raspberry Pi with a thermal pad to make direct contact with the chip. It already helped temps quite significantly (approximately -5°C). If your case has great airflow, a fan seems unnecessary imo.
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
https://linustechtips.com/topic/751409-m2-fan/#findComment-9509074
https://linustechtips.com/topic/751409-m2-fan/#findComment-9509113
I agree with above... if you have good/moderate airflow in your case, the heatsink will do very little if anything to help with temps... adn could even make it worse in some situations. I have pretty good airflow in mine and have never seen my m.2 drive go above approx 46c, and it is situated on the underside of the mobo too. I'd say, if you haven't built the system yet, and the m.2 would at least be accessible after build, then wait and see what temps you get before deciding.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/751409-m2-fan/#findComment-9509163
https://linustechtips.com/topic/751409-m2-fan/#findComment-9509205
2 minutes ago, roylapoutre said:
Awesome. Thank you both. I'll see how it goes with and without the heatsinks and see what happens.
https://linustechtips.com/topic/751409-m2-fan/#findComment-9509215
