Hello. I am planning to build a new pc around 750$. I have chose some parts. Iwould like to know if all the parts are compatible together and also, i need your opinion about the graphics car i could use. Finally if a 550w psu will be enought. I want to mention that i live in Cyprus and product availabilty is low.
CASE COOLERMASTER MASTERBOX 5 WHITE
PSU FRACTAL DESIGN INTEGRA M 550W
CPU INTEL CORE I5-6500 3.20GHZ LGA1151 - BOX
MOTHERBOARD ASUS B150-PRO
RAM HYPERX HX421C14FBK2/8 8GB (2X4GB) DDR4 2133MHZ DDR4 HYPERX FURY DUAL CHANNEL KIT
ASUS AMD RADEON RX470 STRIX-RX470-O4G-GAMING 4GB GDDR5 OR ASUS GEFORCE GTX1050 TI EX-GTX1050TI-4G 4GB GDDR5
SSD CORSAIR CSSD-F240GBLEB FORCE LE SERIES 240GB 2.5'' SATA3
https://linustechtips.com/topic/751312-need-help-for-new-build/
Theres that magic thing of pcpartpicker.com, create your build ideas there and copy the bb code and post it here.
Everything you have selected will work together, though you are missing ram, storage and a gpu. GPU guess would be for example a rx470/480
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/751312-need-help-for-new-build/#findComment-9508135
21 minutes ago, 19_blackie_73 said:
pcpartpicker.com
Did it for you :D
https://pcpartpicker.com/list/qCKZvV
For PSU 550Watt is fine. More is overkill.
For GPU take the RX470 it's a bit better then the 1050.
The parts are compatible. If you look in pcpartpicker it will tell you if you look at the top right.
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/751312-need-help-for-new-build/#findComment-9508218
