Blue tint on monitor
cplus 2296
So i just got my second monitor set up, its connected with an hdmi to Dvi-D cord. Now once i connected it it gained this slight blue tint that it didn't have before, i changed the color profile from RGB to the YCBCr444 and it did nothing. The pins on the DVI-D side aren't bent or out of line so i'm not sure what has happened. Does anyone know a fix for this.
AMD card?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
