Motherboard for a 6700k/7700k and 1080 or 1080ti build
I've been wondering if my asus z170 pro gaming would be enough for the 6700k and a gtx 1080. Also i've been thinking of getting the new 1080ti but the thing is that i am not certainly sure if my motherboard is good enough for that. Since the new graphics card is a killer.  Mind helping me out ? :)
Thanks.
yep, although that mobo may need a bios update for the 7700k it should be fine
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
why wouldn't it be good enough? :)
Main PC:
CPU: AMD Ryzen 5 5600X | RAM:Corsair LPX 3200 mhz (16Gb)
Mobo:ASUS Strix B550-F Wifi | GPU: MSI RTX 2070 Gaming Z
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Be Quiet straight Power 10 500 watt
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Samsung 8 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
:D Actually the new bios update from asus fked up my motherboard, my pc cant boot now. Ive tried everything also dont want to buy a new bios chip yet since its still in the warranty and i can get it for free.
I was just wondering if i dont need some high-end motherboard for the cpu and gpu :)
Just now, KreckyN said:
:D Actually the new bios update from asus actually fked up my motherboard, my pc cant boot now. Ive tried everything also dont want to buy a new bios chip yet since its still in the warranty and i can get it for free.
Everything...
Cmos reset?
just RMA the damn thing :)
Nope. Lots of people run gaming systems on cheapo mobos. Dont expect the best OC on a cheap motherboard.
nah, it's good. You can even get the lowest-tier z170/270 and it's will still be fine, altrough you don't get many mobo features :)
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Galaxy A50
Not really planning on overcloacking anything ^^
Also forgot to ask, will be my 620w psu enough , or can i calculate it somehow ?
Don't bother with a Z series board and k- series cpu, get a h270 + 7700 (non k) and use the money saved towards a 1080ti
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Also :D sorry for bothering but Ive heard that 7700k is overheating a lot. wouldnt it be better to just take the 6700K instead ?
Thanks for an advice ! :)
Can you also read the things i wrote above and help me out if you dont mind :)
Thats people overclocking them, they get F.HOT at 5ghz, 240mm AIO cooler should keep that in check
6 minutes ago, KreckyN said:
Also forgot to ask, will be my 620w psu enough , or can i calculate it somewhere ?
Is it a good brand? How old is it? Generally speaking a good 550w PSU is good enough for a modern PC, provided it isnt using multi GPU
Nope, as long as it is PCIE Gen 3 it will be fine - Just make sure it's compatible with the CPU you choose
Ryzen Ram Guide
The psu is nearly 1 year old exactly Seasonic S12II-620 this one i think.
. So i should be okay with my scythe scnj - 4000 ninja 4 you say.
Ninja will be fine as you should be getting the non-overclock 7700 who's temps arent quite as extreme
Ryzen Ram Guide
Mkay :) do you know what temps does that cpu run at ? idle, while gaming.
