How much power can a power brick supply?
Solved by Pendragon,
msi has been doing stupid hybrid power since forever. if your power draw exceeds how much ur adapter can draw, it'll drain battery as well. When you hit 0% battery while plugged in all your components will start massively throttling to keep the computer on. there's no harm but it's just a dumb design. It existed with the GT80s as well.
Check if the newer GE series have a higher rated adapter with the same connector, they normally keep these things consistent. Aim for the 230w ones since your power draw is at 200w or so.
