Need help with speakers: ELAC B5 w/ BIC America f12 vs Vanatoo T1
3 hours ago, RexAevum said:Thank you for your reply, really appreciate it;
It's really not, what I am looking for is clear sound for music, but I do want some boom to it for games and movies. What is very important to me is soundstage and imaging, way more than how loud the sound can go or how much bass they have + if I want bass I can just get a sub! It's kind of hard to tell from the reviews online which speaker has what since apparently all of them are amazing.
You recommend the vanatoo t1 over the elac's then - thank you very much
You would definitely be served better by adding a good sub later on. The F12 is okay for home theater but not really serious music reproduction.
The T1 are definitely a step above the Elac B5, no question. If they weren't an option, I would suggest the Philharmonic "Affordable Accuracy Monitor" and an integrated stereo amplifier for around $200-300. This would technically be the more "purist/audiophile" option as the T1 uses a direct drive digital amplifier with DSP (so not bitperfect reproduction). But, the footprint difference is significant; the T1 produce deep bass from shoe box size cabinets and connect directly to your computer. They make a lot more sense as high-end computer speakers.
