Build and upgrade later?
Solved by Mr Sporka Dorka,
Just now, Bananasplit_00 said:depends on what you want to do with it and if you need it now or not. if you have something that meats your demands ok for now then stick with that and get everything at once later, if you just need a new computer right now then get the pentium build now and upgrade later
my parents need a pc (they work with it and it's getting really old and slow) and i´m planning on giving them my laptop that i´m using right now so i guess i'll start building with the pentium
