Hey guys I have 2 1080p monitors and 1 1440p 144hz gsync in the middle but nvdia surround won't configure and says they are different timings :/  anyone managed to set up a similar config if so please help
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/747400-nvdia-surround-help/
No. My brother attempted to set up Nvidia Surround on his own system. With the games he plays, it caused issues with regard to UI scaling, and for Black Desert Online, completely distorted the image.
If you insist upon setting up Nvidia Surround, I would recommend you get a third 1080p monitor of similar spec (doesn't necessarily need to be from the same brand), and then set up Surround that way. I don't think it's possible at all to set up Nvidia Surround with different refresh rates. Correct me if I'm wrong guys.
If you're going to ask, @Candren Lycosa is my brother.
Edited by JurunceNK
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9465286
I'm pretty sure they have to be the same refresh rate.
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9465290
That's what I'm stating too when I said "similar spec", so I'm including resolution and refresh rate. Doesn't need to be the same panel type or size though. biggrin.gif
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9465294
Ok but I set my 1440p monitor to 60hz and still nothing
also (1600)
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9465541
There is a possibility because you have 2 diffrent monitors. If you had 3 same Monitors it would configure without issues.
Seen this issue before.
Challenger Tier at League of Legends since Season 5.
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9465556
Need to set the 1440 to 1080 then do it.
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9467298
Iv don't that still nothing works
also (1600)
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9492065
If they are all set to 1080p and to the lowest refresh rate of the slowest monitor. Need to be on an appropriate display output too. What card is being used?
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9492084
You can have different refresh rates for the monitors (I believe my left monitor goes up to 1080p 30 hz) BUT it lowers ALL of the monitors refresh rates to the one with the lowest refresh rate. also I don't recommend using NVIDIA Surround due to the fact that most games have issues with it.
https://linustechtips.com/topic/747400-nvdia-surround-help/#findComment-9501247
