Can an ungrounded outlet damage a PC and is there any way to fix it?
Solved by W-L,
17 minutes ago, FabulousGamer said:-SNIP-
It's less of a worry to the PC as a safety hazard as it can potentially build up a a dangerous amount of charge which can shock you if you were to touch the case. It's more of safety than anything else as mentioned a UPS will not help as it needs a ground pin, your best option would be to have someone come in a see if they can properly install a ground or remedy the issue of the lack of grounding in the whole home.
