OK - So I am overclocking my CPU for the first time and it's not showing up in windows, but on boot bios says my clock speed should be 4200 mhz. (set to 100mhz x 42)
in windows: https://gyazo.com/214acb723a96882d47489aff88db7048
Is this normal? Which one is the actual clockspeed?
Thanks.
MSI z170a Krait gaming 3x
MSI Click Bios 5
i5-6600k
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
https://linustechtips.com/topic/745480-overclocking-questions/
That is normal.
You would need another program to look at the clock speed. You can use task manager in the performance tab to get a rough idea though it's not always accurate.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443537
2 minutes ago, DragonTamer1 said:
That is normal.
What's a good tool to stress test?
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443555
Thanks.
MSI Click Bios 5
i5-6600k
Windows properties shows only base clock/frequence of the processor. It doesn't measure anything at all.
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443556
Just now, deXxterlab97 said:
AIDA 64 but it costs. There's a 30 day free trial
Any free ones? I don't want to get used to a paid program because then I'd be tempted to pirate it after the trial expires.
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443568
@deXxterlab97 @DragonTamer1
How long should i let the stress test run before I go and boost the multiplier some more? It's been about 10-15 min of all 4 cores at 100%
https://gyazo.com/249e3bba54c7a15dfd2bb6b3a90fcadd
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443653
Windows does not show proper CPU frequencies, you need to use proper software like HWmonitor, CPU-Z, etc etc etc.
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443654
using NZXT CAM and it's working nicely.
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443659
Whenever you feel like you can bump it up.
Usually if it is going to crash it will do so in about 5-10 minutes most of the time.
Keep turning up the frequency until you get crashing, turn the frequency down until it stops, or turn up the voltage.
 Sometimes a system won't crash under full load but will crash under moderate load. My 2500K system will crash at 4.5 between 25% and 75% load but is fine above or below that.
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443665
Last question -
What's a good temp at 100%? Is 70 degrees C a good temp to leave at max?
@DragonTamer1 @deXxterlab97
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443773
80*C would be the maximum recommended. Anything above that and you should be worried.
70*C is fine, not the greatest but perfectly acceptable.
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443788
3 minutes ago, deXxterlab97 said:
what cooler. 70 is fine
NZXT Kraken x62
haven't even hit 65 yet and at 4.8ghz :D
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443814
NZXT Kraken x62
4.8? The hell kind of voltage are you pushing through it?
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443822
i have no clue what I'm doing with voltage, to be honest. CAM says 1.14v
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443827
Try using CPUID and HWMonitor to check for CPUVcore.
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443841
https://gyazo.com/602ac9466cb79dde26425dd15c8fceba informative?
edit goddamn is 1.5v a lot
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443856
Pull your voltage WAY back, you are torturing your CPU.
Don't go over 1.4V CPU core in CPUID, 1.45V if you don't care about longevity.
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443870
Don't go over 1.4V CPU core in CPUID.
I didn't set it that way... it just happened?
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443876
In your BIOS manually set your CPU voltage to 1.4V, if it is set to automatic the BIOS is giving the CPU the voltage that it is asking for to maintain its frequency.
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443890
Alright, let me do that
qυoтe мe pleaѕe!
https://linustechtips.com/topic/745480-overclocking-questions/#findComment-9443893
