dual curved monitor
DrProfSagi
I currently have a curved monitor from samsung the c24cf390fh 24" monitor. I am looking to buy another monitor, to have a dual monitor setup, my question is, will it be comfertable to game on, will the bazzels disturb me too much? Will it be okey to have two curved monitors? Should i go for a flat one? Should i save up and go straight to three monitors?
Thank's alot and sorry for grammer, spelling and such :)
ive used every monitor setup under the sun. And I think the best is using a single ultra-wide curved monitor.
But if you really want two screens then the bezels on the monitor you have shouldnt be an issue.
Game resolutions wont always play nice though.
CPU: Amd 7800X3D | GPU: AMD 7900XTX
With two monitors you'll have the bezel right in the middle, to me that would make any game unplayable.
Two curved monitors can look great and is fine for productivity but I wouldn't buy that for gaming.
And is you're considering 3 monitors you might as well invest that money in 1 single much larger display.
Does you mum know you're here?
the thing is that i allready own a single c24cf390fh.
if i get a big widescreen curved monitor, could i still use the monitor i got? do i have no use of it?
