Switching Motherboard - Imminent system damage?
Solved by Dabombinable,
13 minutes ago, insyght said:Did you still uninstall all the old drivers?
I guess so, otherwise Windows wouldn't go on to search for new ones
I didn't change a thing. Simply turned off the laptop, switched it for the 60GB SSD in my desktop and it was fine. Windows 10 will at the very least install basic drivers if its missing the official ones (which is where you have the ones specific to the new motherboard unpacked and on a USB stick).
