When I originally got my laptop I was surprised to notice that the games I played on it where running surprisingly well for a laptop however, the stats on this laptop are above some of my friends yet runs programs like Visual Studio, Solidworks, and Photoshop really slow and I experience crashes in Solidworks doing the simplest of things. I was wondering if anyone has experienced the same thing and what I can do to fix this. I've tried solutions such as turning off startup programs not needed and cleaning my disk and have not have had as large of a impact. Let me know whats worked and how to fix it. Thanks ahead of time.
https://linustechtips.com/topic/744290-need-help-getting-programs-to-run-faster/
Get a SSD. It makes a world of difference, trust me. My laptop was literally brought back to life after a SSD upgrade.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I would except I plan to build a desktop after May and I'm looking for a quick solution. But thanks for the advice.
laptop specs?
There is no quick software solution. Get a ssd. Its worth it.
Well unless you're up to reinstalling Windows and all of your programs (won't be as effective as getting a SSD, but would make it at least somewhat more stable than it is now)... there isn't a easy solution.
3 minutes ago, Dutch-stoner said:
Being very slow is no reason for crashing... I wonder if you have other issues.
It's very possible for the two symptoms to appear together when the issue is hardware bound. Bad HDD could lead to slow read/writes and lots of errors.
That makes sense. However would it just make more sense to wait till May for a desktop since the memory on my hard-drive is almost full at 2 Tb and its more per gigabyte for SSD?
If you could wait that long. Alternatively you could reinstall Windows which would restore some stability. But it's a temporary fix, the symptoms will return after another year or so once files start getting degraded again. For your desktop, would recommend a SSD for boot, and a HDD for storage and overflow for programs. So only have Windows and your commonly used programs on your SSD as space is limited.
I know first hand Visual Studio (with addons especially) is slow on a mechanical drive.  There's just so much stuff it needs to call on so the load time for it is awful.  I agree with everyone else - SSD will do wonders.
