I just finished setting up my new computer and it gives me this error every time it boots up i look in and i see the coolermaster fan spinning and it forces me into the bios every time. The bios then reads the cpu fan and says that it is fine and show no other fan slots filled this is normal because i have them on the fan controller built into the case. the only fan on the mobo is the cooler master evo 212 one... how do i fix it :)
Asus G74SX,17.3" 1920x1080 Screen, Intel® Core™ i7 2630QM 2.2GHz, 2.9 Turbo, 12GB DDR3 1333 MHz SDRAM, NVIDIA® GeForce® GTX 560M with 3GB GDDR5 VRAM, 1.5TB (2x 750GB) 7200rpm HD Windows 7 Home Premium 64-bit. [] Asus VivoBook S400, Intel® Core™ i5-3317U Processor 1.7 GHz, 4 GB DDR3 1600 MHz 14.1" LED  (1366x768)  touch panel, 500GB HD, Intel® GMA HD, Windows 8 (64-bit)
https://linustechtips.com/topic/74293-cpu-fan-error/
try another fan
Listen if you care.
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1018001
try another fan
Per haps if nothing else works but i really do not want to tear apart the whole thing and now after installing the intel chipset drivers it seems to have stopped doing it.
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1018038
Can you set the CPU fan status to ignore ? norm possible where it reads the RPM
Quack 🦆
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1018040
Yes I can new to the fancy bios stuff i thought that would shut the fan off ... Its been five years since i built a computer thanks :) will do that on next boot.
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1018072
NP let us know if you fix it  :lol:
From what I can tell that fixed it now dumb question was that just some strange issue because why would ignore the fan speed fix it... also it was always red saying the fan was only like 500 rpms... there is also an cpu optimum fan speed.. did i plug it in the wrong slot cause the mobo has 2 fan slots
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1018109
probably put it in an optional fan header... or the bios is expecting the high rpm stock fan. I wouldn't be too worried, as the thermal limits will stop the pc if the fan dies.
Sent from my SPH-L710 using Tapatalk
Come fold while not gaming! http://linustechtips.com/main/forum/37-foldinghome-boinc-and-coin-mining/
Gaming Rig: i7-9700k 5GHz all core, GTX 1070, 16GB TridentZ, Buncha ssds...
Stream Machine: R7 1700, GTX 660 (lol), 16GB Corsair Somethingoranother, 120 GB SSD i've had since 2012.
Mobile Workstation: MSI-ALPHA :R7 3750H, RX 5500M, 16GB of some ram, 500GB SSD.
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1021526
I used to get this one all the time on my last PC with an asus mobo.  I also use AI suite II.  I think I just made sure everything was set defalt in the bios fan settings and only used the fan settings in AI suite II.  Im not exaclty sure what happened but the cpu fan error seemed to fix itself.
I had thought the fan error could have been triggered by a false low rpm fan warning which said the fan was running at 0 rpm when it was actually working fine..
EDIT: also try updating bios if your not using the latest..
𝘛𝘳𝘶𝘴𝘵 𝘺𝘰𝘶𝘳 𝘪𝘯𝘵𝘶𝘪𝘵𝘪𝘰𝘯
PC: ibuypower pre-built RDY Y70
Cpu: i9 14900K  Gpu: Zotac 4070 super ti  Ram: 32Gb DDR5  SSD: 2Tb
Case: HYTE Y70  MB: MSI 790-P wifi
Cooling: ibuypower 360mm RGB aio
Laptop: Lenovo Legion Pro 5i, u9 275HX, 32gb ddr5, 5070ti, 1tb SSD, 16" 165hz oled
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1024417
do you by any chance have a ROG motherboard ?
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1024423
Nope i do have an asus z87 pro
https://linustechtips.com/topic/74293-cpu-fan-error/#findComment-1026910
