computer with 2 GB of VRAM and a quad core 16GB RAM with 1TB of memory. Just needs to run basic editing programs and some games off steam,
don't need monitor keyboard mouse or Windows I have those.
budget is around 400$ usd IF possible. Doesn't need to be skylake or kaby if that cuts costs, any build ideas?
https://linustechtips.com/topic/742736-budget-build-help/
2 minutes ago, Dawson Wehage said:
Not sure if the 16GB of memory is possible with $400 Maybe you can bump up to $700 for something better.
Yeah I feel you it's not for me or else I would, I found some  builds with 8gbs but my friend insists on 16 for some reason.
https://linustechtips.com/topic/742736-budget-build-help/#findComment-9413545
1 minute ago, Lol_Someoneactually said:
Do you know of anything decent?
any dell hp or acer computer with a 2nd - 6th gen processor should be good - buy some ram to upgrade if they don't have 16gb in it, and buy a 1050ti or rx460
https://linustechtips.com/topic/742736-budget-build-help/#findComment-9413569
RX 470 is double as good as the RX 460 and only like 50% more expensive
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/742736-budget-build-help/#findComment-9413590
rx 470 needs power from the psu and can't just use mobo power - then he'd have to upgrade the psu
Hm...
Sometimes the PSU has an extra 6-pin, if so, then he should definitely get a 470.
otherwise, buying a $40 PSU basically makes the RX 470 not really worth
Laptop:
https://linustechtips.com/topic/742736-budget-build-help/#findComment-9413708
5 minutes ago, RAM555789 said:
You can get much cheaper RX 460s
Laptop:
https://linustechtips.com/topic/742736-budget-build-help/#findComment-9413712
5 hours ago, RAM555789 said:
Show me
https://www.newegg.com/Product/Product.aspx?Item=N82E16814131695R&cm_re=rx_460-_-14-131-695R-_-Product
Edit:
Nevermind, I thought your RX460 was $100USD
Laptop:
https://linustechtips.com/topic/742736-budget-build-help/#findComment-9416381
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($61.99 @ Jet)
Motherboard: Asus H110M-E/M.2 Micro ATX LGA1151 Motherboard  ($46.98 @ Newegg)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2400 Memory  ($51.88 @ OutletPC)
Storage: Western Digital AV-GP 1TB 3.5" 5400RPM Internal Hard Drive  ($37.99 @ Amazon)
Video Card: PowerColor Radeon RX 470 4GB Red Dragon Video Card  ($129.99 @ Newegg)
Case: VIVO CASE-V00 ATX Mini Tower Case  ($27.99 @ Newegg Marketplace)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($41.98 @ Newegg)
Total: $398.80
Generated by PCPartPicker 2017-02-24 01:03 EST-0500
https://linustechtips.com/topic/742736-budget-build-help/#findComment-9416413
Total: $398.80
Thats is the better choice. While the price of the mobo makes it seem cheap, but after reading the reviews I can see its a very good mobo and even comes with a UEFI.
https://linustechtips.com/topic/742736-budget-build-help/#findComment-9417178
