Hello there once again I find myself encountering almost the same problem I had a long time ago.
I use my R9 290X (4GB) on my daily use computer and since I've had it for almost 3 Years now I noticed from the start the performance wasn't so great, but I'm sure if it was for some other reason
it would've gone away when I upgraded my PC to Kaby Lake, but still the issue is there.
now one thing that boggles my mind is that I have the GTX 1050 (2GB) Mini from Zotac and then when playing the same games I tried for cards I think 1050 runs better, Titles such as Battlefield 1, Mafia 3, Assains creed Unity, and so on.
When I tried to do the benchmark on Valley the R9 290X got a score of 1614, and the GTX 1050 got one of 1315.
Shouldn't the R9 290X outperform 1050?
https://linustechtips.com/topic/741786-help/
Take into consideration all the games you listed are fairly recent and the 1050ti is the latest most supported product in nVidia line up while the 290x is years old with already limited driver support, even if raw power is superior on the 290x it can not deny its age, it could be the action if time, dirty cooler, many things since it isnt a specific driver issue
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/741786-help/#findComment-9403437
well yeah, but I cleaned my card R9 290X with new thermal compound, new pads, and so on.
also, The 1050 I have is not the Ti
https://linustechtips.com/topic/741786-help/#findComment-9403493
