Budget: <$1500  Location: Florida  Purpose: Gaming
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($189.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($27.88 @ OutletPC)
Motherboard: MSI B150 PC Mate ATX LGA1151 Motherboard  ($79.88 @ OutletPC)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($112.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($159.99 @ Jet)
Video Card: Asus GeForce GTX 1070 8GB Video Card  ($404.99 @ Newegg)
Case: Corsair Crystal 460X RGB ATX Mid Tower Case  ($139.99 @ B&H)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($50.89 @ Newegg)
Total: $1166.60
https://linustechtips.com/topic/741625-rate-muh-first-build/
9 minutes ago, xxxtentacion said:
Budget: >$1500  Location: Florida  Purpose: Gaming
Total: $1166.60
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($299.99 @ SuperBiiz)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($99.88 @ OutletPC)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  ($72.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($379.00 @ Jet)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ B&H)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($73.99 @ Best Buy)
Total: $1120.05
Generated by PCPartPicker 2017-02-21 14:43 EST-0500
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401179
Total: $1120.05
Awesome, thanks!
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401205
35 minutes ago, deXxterlab97 said:
No need for Samsung SSD
No need for a cooler
Please explain?? Intel stock coolers are garbage, may not need more cooling but the sound is awful in ANY build. And why not a Samsung SSD?
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401362
Why spend extra 20-30 dollars so you can get a maybe quieter sound? At idle it doesn't sound that loud like people like to exaggerate. And at load it doesn't sound bad too and most people game with a headphone.
Why not Samsung SSD? They are overpriced. Sure they are great but you can get more storage for same price
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401370
The sound is not exaggerated on stock coolers, my machine with a 6600k as well as my machine with a g4400 were super loud before I upgraded to that cooler, if someone wants a quieter pc but doesn't need crazy amounts of cooling, the hyper 212 is a great buy, there is a reason it is so popular. looks better too imo.
Samsung SSD's are well worth the cost. Read/write speeds are better than most ssd's and they are very reliable, Especially if he is willing to pay for it.. I just don't understand.
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401390
I used stock cooling all the time and seriously they're not that loud. It has improved a lot over the past 20 years.
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401396
Both of mine were terrible, I don't use headphones and when gaming they were very loud.
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401403
1 minute ago, NumLock21 said:
Then it's not the fan, but your board.
I don't understand what you mean by that, the sound was gone when I replaced the cooler, If I lowered the RPM on the fan, the temps went up to high.
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401414
Need to make sure pwm is enabled and your prefer fan profile is set. On Asus boards, it's either optimized, silent, or performance.
CM 212 Evo at max rpm is loud 2000rpm or 1600rpm for EU.
https://linustechtips.com/topic/741625-rate-muh-first-build/#findComment-9401448
