Which one would you get?
5 members have voted
  1. 1. Which one would you get?
    • Sandisk
      4
    • Delkin
    • Lexar
      1
Alrighty Then.
With the advent of the Nintendo SwitchTM, SD cards with high, constant Write speeds are crucial, if you plan on going mostly digital with your new console.
Problem is, there seems to be very little choice, and not much new in this arena. I've only found three that were suitable in my eyes, but two out of the three
I have were released in 2014, the last being released in late 2016. I was wondering if speeds could have been improved since then, and if not speed,
at least price or size. Just to keep things simple, UHS-II U3 class SDXC cards will probably be the only ones mentioned.
Here's the three I've Found:
Lexar 64GB
Sandisk 64GB
Delkin 64GB
I was searching for 64GB in particular, but these three have 128GB variants as well. This might just be a me problem, as all three of these boast write speeds of over 200mb/s.
I guess what I wanted to see, is if there are any SD cards that I'm not aware of that are faster, cheaper with the same speed, or something else. What also worries me is these
speeds they tell you are often not constant read/writes, but bursts. Am I being too picky on the three choices I've found, or is there more out there I'm unaware of?
Edit: For blind peeps, text size was upped.
https://linustechtips.com/topic/741512-top-dog-sd-card/
I've never heard of Delkin before, but what's up with the weird formatting? Your text looks like this.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/741512-top-dog-sd-card/#findComment-9399871
well, it's gonna sound a bit fanboy-y, but sandisk has yet to let me down, and i unfortunately cant say the same about kingston, adata seems to be on par with sandisk (but i'm talking about literally one device worth of experience), and samsung SD cards are quite literally hilareously expensive compared to the rest.
which... kinda covers all brands of SD cards i can get my hand on. i have *one* lexar usb stick, and it's quite literally my "only used for the rare occasion i need a lot of data" drive, because it's the biggest one i have, and even counting my pair of 256MB drives, the slowest one in the bunch. i dont know what they did wrong with that thing, but it's painfully slow.
https://linustechtips.com/topic/741512-top-dog-sd-card/#findComment-9399879
1 minute ago, manikyath said:
looks like the same type of brand that came with my 3D printer for storing gcode files, which has only corrupted on me twice so far.
That's useful. "Hey drive, go and corrupt all my data for me." "Oh crap."
Main System: Phobos
https://linustechtips.com/topic/741512-top-dog-sd-card/#findComment-9399886
On 2/21/2017 at 11:27 AM, Greatest Cupcake said:
So Delkin might not be the best choice, at least in terms of reliability. But both Lexar and Sandisk have been proven to be incredibly reliable. Any from Samsung with 200+ write speeds?
(super late on this but this tab has been open since like an hour after you made this thread)
I've had an 8GB SanDisk card since around 2010 and it has worked bombass flawlessly other than the casing starting to open up at the connector end. SanDisk gets all my votes.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/741512-top-dog-sd-card/#findComment-9414667
