hi so i bought a gtx 280 for 10 euros to replace my completly dying gts 250 and the card seems like its stuttering even at a game like league of legends i get fps drops to 15 fps  my specs are c2q q8400 mobo ga-p31-es3g 4gb of ram and a 120gb  ssd any suggestions ? (atm im replacing the cooler to a better one )
https://linustechtips.com/topic/741186-gtx-280-problem/
Instead of circling around the same PC which is really old, why don't you try getting a new one?
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/741186-gtx-280-problem/#findComment-9395855
The GTX 280 is a power hungry card. Assuming the card is still alive, what PSU are you using?
My eyes see the past…
My camera lens sees the present…
https://linustechtips.com/topic/741186-gtx-280-problem/#findComment-9395910
Yeah I would get a new one with an Intel Pentium g4560  which is about $57 euros a cheap gigabyte H110-M S2H which is about $61 euros which is about motherboard with 8gb of 2133mhz ddr4 ram in Australia you can pick it up for about $80 which in euros would be about $57. for your GPU you could get an RX 460 which in euros is about $136 euros or if you just want to play games like league of legends. then you should just get a gtx 660.A 1tb HDD which is only about $69 AUD which in euros would be about $49 euros. and to power everything you can get a 550w PSU for about $47 euros
hope this helped.
https://linustechtips.com/topic/741186-gtx-280-problem/#findComment-9395934
corsair vs 650w
20 minutes ago, deXxterlab97 said:
Usage and temps? Maybe it is dying already hence that cheap
about 35%usage about 73c on load btw im gonna try it in another pc while im busy mounting new cooler
https://linustechtips.com/topic/741186-gtx-280-problem/#findComment-9395971
hope this helped.
OP spent 10 euros on a video card. Something tells me that OP doesn't have the capability to multiply the upgrade budget many times over.
Replacing the thermal paste on the GPU would be a good start, especially if the stuff is original. Also, what temps is the cpu hitting?
https://linustechtips.com/topic/741186-gtx-280-problem/#findComment-9396013
