Condenser mic crap recording quality
Solved by RainColt,
On 2/18/2017 at 6:41 PM, robinhood22 said:actually i wasnt monitoring the sound at the same time i would plug the mic in, record, then listen with headphones. i was using audacity with a 48000hz setting but the problem persists even is obs(btw i even tried it on my desktop same thing) im about 5-10 cm away from the mic, and im using windows 10, how do i turn the line level down if its the only device im using?
I thought I responded to this sorry.
Its the same as your system input/recording level. Just try dropping it to .65 maybe, also when you click to start monitoring what are you peaking at? should be around -12
