Im looking for a case for a LAN PC, ive been looking at the node 202 https://www.newegg.com/Product/Product.aspx?item=N82E16811352059 (with the power supply) for a while now. I was wondering if there are any similar cases like the 202? I will want to fit a full sized gpu if possible and it should be able to fit in a large backpack. Also my max budget for both the psu and case is 120 - 140. this will be housing a g4560 and cpu i have yet to decide (will upgrade to i5 in future)
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/739515-lan-pc-case/
4 minutes ago, opersg said:
ive seen that but is 195 dollars...
https://linustechtips.com/topic/739515-lan-pc-case/#findComment-9379480
It's sad they dont make the Corsair 380T anymore...
https://www.newegg.com/Product/Product.aspx?Item=N82E16811112348
https://linustechtips.com/topic/739515-lan-pc-case/#findComment-9380273
