Need opinions on fan setup
Milos Sladic
Hi,
I ordered Fractal Design Define Mini C case. I will be using noctua NH-D9L cooler and sapphire nitro+ rx 470.
I was planning on using 1x NF-S12A PWM in the back and now comes the question:
Should I use 3x NF-S12A PWM in the front or 2x NF-A14 PWM?
I would like to keep the top closed, coz I am going for complete silence.
Thank you.
If you are going for silence you should go for the two in front. + You got a small case so its no problem with only three fans in total.
