i5 750 liquid cooling
Solved by Streetguru,
17 minutes ago, tismanasou said:Hi guys i want to overclock my i5 750 to 4.0Ghz, thus i need need liquid cooling, i was thinking to buy COOLERMASTER SEIDON 120V V3 PLUS. They are compatible, but will i have any problems with heating? Is this liquid cooler enough? Its on sale (64euro) so i really need a fast answer. Also if its not enough, how much hertz can i push it with this liquid cooler?
Is the space in your case very limited or something? Because a 120mm AIO isn't much better than something like a Hyper 212, so probably stick to a Hyper 212 or GAMMAX 300
https://de.pcpartpicker.com/product/hJFPxr/deepcool-cpu-cooler-gammaxx400
Maybe just upgrade the fan to like a Fractal Venturi HP-14 for better air pressure on it
