Native windows and just switching between mirroring mode and separate display mode :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
lol, i need something that sends the same signal for the 2 displays but i want to be able to put on a screen saver in one of them so the audience cant see what im doing between topics
Well at least on Mac OS, when you have multiple monitors connected, you can easily do that as there's a dedicated icon in the toolbar which allows you to switch between the different modes :P
In whindows, I'm pretty sure there are hot keys for it so...
And yes, mirrored makes both displays have the same image while separate makes them have different images...
DisplayFusion has function where you can set different profiles for monitors. So not really force to screensaver, but disable 2nd monitor with hotkey.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
