I think there are certain cases which just have this and they use a pci_e extender cable to hook it up to the MOBO. It's defenitally not the most efficient or easy way to have a gpu in a pc.
01110101 01101100 01100100 00100000 01100100 01101111 00100000 01110011 01110101 01100011 01101000 00100000 01100001 00100000 01110100 01101000 01101001 01101110 01100111 00101110 00101110 00101110 00100000 01010111 01100101 01101100 01101100 00100000 01101000 01100101 01110010 01100101 00100000 01101000 01100001 01110110 01100101 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101111 01101011 01101001 01100101 00100001
37 minutes ago, Cybernetic Organism said:
Hi,
I saw this picture that rog shared and I wanted to know how to place the graphics card so it faces the window. Anyone have any idea?
Thanks.
certain cases, e.g. the Deepcool genome case, have vertical expansion slots  which means that is  you use a riser card (they might be included, might not) you can have a vertically mounted graphics card in it, showing it off
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
