I'm building a new pc, and looking at £20-30 cases with a relatively clean look and a decent side panel. If i had a little more money (or could squeeze it into the budget) i could buy a case like the versa h15 or better. If i had even more, i would get the nzxt source 340. Is it worth trying to squeeze these into my budget just for aesthetics and (maybe) better radiator support? Also is it hard to upgrade your case to something nicer?
I was looking at this case https://www.cclonline.com/product/225388/CIT-DARKSTAR/Cases/CiT-Dark-Star-Midi-Tower-Case-with-120mm-Blue-LED-Rear-Fan-Side-Window-Black-/CAS2893/ but will the psu shroud cause issues with only 2 cable management holes? I would be using the corsair cx450m?
https://linustechtips.com/topic/736634-is-a-better-case-worth-it/
Welll performance of a case is a bit depending on quality and fans used. But if you replace bad fans with decent ones it can be ok. But don't expect the best sound dampening. Also quality of life aka ease of building in can be less optimal. No rubber grummets and holes or plates covering stuff. But it can suffice if you don't care about that and looks and are ok with the performance.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
Any reccomendations
i have the in win gt1 and i cant fault it other then drive bays cover the front fans a bit but theres 4 other fans u can put in and fan controller comes with it
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
1 minute ago, Ethan Meskin said:
no offense but that is uglyyy
each to there own i really like it but looks a side get something with cable routes and a "lip" on both sides so cable management is not a bitch
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
and i have the full window side panel in black with the red "rings" on the front
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
Corsair ahs several good ones, Be quiet silent wings seem to be good and ofcourse Noctua are in general cosidered great, but that might become a costly adventure.
PSU Tier list
There are three things I look for in a case, outside of the obvious compatibility issues.
1) Aesthetics. I want to enjoy looking at it from time to time.
2) Cable management. Making everything neat is easier for replacing or adding parts, improves airflow (although that may not be as important as once thought, based on a video Linus Tech Tips recently did), and just makes it look nicer overall my.
3) Front ports, especially USB ones. I want to he able to plug in multiple USB devices at any time without having to grope around the back.
If you're getting a cheap case, it's probably going to have bad cable management, so I don't recommend getting one with a window.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
The 2 i looked at had 2 2.0 and 1 3.0 . One had a PSU shroud and the other had a huge bulge for cables http://www.aerocool.com.tw/us/chssis https://m.cclonline.com/product/225388/CIT-DARKSTAR/Cases/CiT-Dark-Star-Midi-Tower-Case-with-120mm-Blue-LED-Rear-Fan-Side-Window-Black-/CAS2893/ the second one looks better
corsair 88r worth it?
The cable management isn't very good on that, and it only has two USB ports.  I know from experience that the cable management is excellent on this one though.  I used it in a build I made for a customer.  However, it does not have a 5.25" drive bay, so if you wanted a DVD drive it's not a good choice.
It's mostly plastic so the quality isn't so the quality isn't up to par with a $100 case, but it's still a great bargain.
5 minutes ago, BazNaz said:
The cable management isn't great on that according to reviews.  It wouldn't matter so much if it didn't have a giant window.
im buying a modular psu, would that help?
Some, but you're still going to have some trouble tucking wires away because of the lack of space behind the motherboard.  Could you post a link to your PCPartPicker list?  Seeing what components you have would really help.  If you haven't picked everything else out, you can fill in a temporary part.  Just mention it.
https://uk.pcpartpicker.com/list/HRdKGf. the psu might change for more headroom with such a beefy card
Thanks.  What was the wrong with the DIYPC one I posted earlier?  I'm not trying to push the case on you, I just want to know what you don't like so I can filter some stuff out.
its kindof ugly. I like sleek simple (black, white etc) cases with a square ish window like the source 340. I would stick a nice top down 120mm heatsink with a blue or white sp120 and a led strip.
Take a look at these:
https://www.newegg.com/Product/Product.aspx?Item=9SIA2F857T4886
https://www.newegg.com/Product/Product.aspx?Item=N82E16811353093
https://www.newegg.com/Product/Product.aspx?item=N82E16811853002
https://www.newegg.com/Product/Product.aspx?item=N82E16811853035
They all have good cable management and I think meet your heatsink needs.  To be honest, a stock heatsink would work fine for your CPU anyway.  Just make sure you use decent thermal paste instead of the pads they include.
the cooler is just for aesthetics and noise
Well do any of those cases look good to you, or was I off on what you want?
