Hello there, I was tasked with making a console program that calculates taxes then ask the user if he wants to restart or leave by pressing 1 or 0 but the program only reads the false condition (leave). I tried to find the error even asking a coder friend but he doesnt do C anymore so he didnt find it. The program is meant to be built around loops so no advanced solutions will fix it. Excuse the french commentary, thx.
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/736265-c-coding-help/
Have you tried converting the user input from string to integer? I doubt it's the error but worth a shot. I haven't done strict C so I am not sure if scanf will set the input to be the value stored at the second arguement. If this code is in C, not just C++ then I'd do
"cin >> ichoix1"
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9346309
First, ALWAYS initiate your flags, preferably all variables. It should read
int iChoix1 = 1;
Second, you should be checking if iChoix1 doesn't equal 0, not if it equals 1. Enter
while (!iChoix1)
Third, just to track this kind of stuff you should have a debug define. At the start of the code after the includes, add
#DEFINE ENABLE_DEBUG
Then, after the scanf("%i", iChoix1) line, add
#ifdef ENABLE_DEBUG
printf("The user entered %i", iChoix1);
#endif[code]
You can do the same thing (but with a different printf if you want) anywhere else. If you comment out the
[code]#DEFINE ENABLE_DEBUG
line all that code will effectively be removed when you compile. It's a way to add or remove all your debug code from the final product with a single action.
Edit: I messed up some of the code tags and I can't fix it from my phone. Would one of the moderators be so kind as to help? The one after the #endif needs to be a closing tag. @wkdpaul
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9346413
2 minutes ago, Xaer0 said:
When you are scanning the 0 or 1 for whether to quit or not, you are using '%i', I think you want to use '%d' for integers.
That's for decimals. He's right to use %i for (signed) integers.
http://www.cplusplus.com/reference/cstdio/scanf/
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9346671
%i will allow any kind of integer, whether it be decimal, Octal, and Hexadecimal. Where as %d will only permit decimal integers (0-9). But Looking at it again, I don't think that is the problem anyway :o
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9346737
No, %i will not allow for decimals. It will convert it to a whole number.
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9348903
13 minutes ago, fizzlesticks said:
Decimal is referring to base 10, not a number with a decimal point.
Oh, I see what he's saying. We were just discussing %d which is for decimals (with a decimal point), thus my confusion.
Anyway, using %i will cast the value as a signed 32 bit integer.
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9349062
No, %d is for integers but only accepts base 10 unlike %i that accepts base 8, 10 or 16. %f, %e, %g and %a are for floating point numbers.
edit: This page has a chart with all the format specifiers http://www.cplusplus.com/reference/cstdio/scanf/
1474412270.2748842
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9349093
Accepting and displaying are two different things.
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9349148
Thanks for the replies, i do 12 hours shift on weekends so il check monday and reply to everyone. Il make sure to copy the code next time too!
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9354202
int iChoix1 = 1;
while (!iChoix1)
#ifdef ENABLE_DEBUG
#endif[code]
The problem is still there.
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360646
On 11/02/2017 at 7:36 AM, NoGravityPanda said:
I think your problem is in your while condition, try instead of doing
iChoix1==1
just do
while(iChoix1)
and just saying- you should never have "junk" in your variables.
int iChoix1=1;
etc.
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360648
8 minutes ago, M.Yurizaki said:
I typed in your program pretty much word for word, except for system("pause") and used scanf("%d", input); instead of %i. I got it to work on my end.
can you be kind enough to send me your code so I can run it and verify if the problem is software or setting sided
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360763
I've taken the liberty to do some "optimizations" while I was at it.
#import <stdio.h>
#import <stdlib.h>
int main(){
  float money, tps, tvq;
  int input = 0;
  do {
    printf("Enter the amount of moeny: ");
    scanf("%f", &money);
    printf("Money before taxes: %.2fn\n", money);
    tps = money * 5 / 100;
    printf("TPS: %.2f\n", tps);
    tvq = (tps + money) * 9.975 / 100;
    printf("TVQ: %.2f\n", tvq);
    printf("Money total: %.2f\n", tvq + money);
    printf("Enter 1 to do again, 0 to quit: ");
    scanf("%d", &input);
  } while(input == 1);
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360802
#import <stdio.h>
#import <stdlib.h>
int main(){
  int input = 0;
  do {
Doesn't work on my end. Il ask my teacher tomorrow and come back to you, thx for helping.
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360826
Please describe what you mean by "doesn't work."
I've compiled this with gcc and it seems to work just fine.
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360834
it doesnt restart just asks again enter 1 or 0 until i enter anything else than 1
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360839
So the output is basically:
Money before taxes: (something)
TPS: (something)
TVQ = (something)
Money total: (something)
Enter 1 to do again, 0 to quit: 1
[repeat forever]
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360875
TPS: (something)
TVQ = (something)
[repeat forever]
yeah
https://linustechtips.com/topic/736265-c-coding-help/#findComment-9360878
