You are saying it is at 10c? That is extremely low, even for idle.
That isn't a great CPU so I wouldn't expect it to run very well anyways.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9343444
the point is that it's not running at 100%, so OP is getting 40% of an already bad CPU.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9343481
32 minutes ago, PolwskiPL said:
can anyone tell me what could i do to get the cpu speed back to normal   ????????/
This is Thermal Margin. This means that the CPU temperature is 7C lower than the temperature at which the CPU starts Thermal Throttling...
@PolwskiPL Replace the Thermal Compound and this should fix the issue...
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9343492
3 minutes ago, PolwskiPL said:
gtx 970  Thermal Compound replaced
Hmm.... Make sure that you have max CPU usage set to 100% in the Power Plan settings in the control panel...
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9343544
already done that do i have to restart my pc when i do it ??
Hmmm. You may have to reinstall Windows then..
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9343559
1 minute ago, PolwskiPL said:
done that too mate ????
Which cooler are you using?
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9343572
14 minutes ago, PolwskiPL said:
stock 1 thats why i think my clock speed is not right on my afterburner the cpu hits 100% but only of 1.39GHz not sure if im right here tho
Reset CMOS maybe?
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9343654
Don't run your games in Windowed Mode.
USE FULL SCREEN.
Speccy is not reading the temperature value properly for AM3+ CPUs (like other programs).
Try HWMonitor instead, or AIDA64, and take a screenshot.
For HWMonitor, you want to be looking at the 'Temperatures' section, NOT 'AMD FX-4300' >> 'Temperatures' >> 'Package.'
Depending on the motherboard that you have, and how HWMonitor picks it up, it may ACTUALLY show up as  "CPU", otherwise, it can be "TMPIN0" or "TMPIN1", etc.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9344055
USE FULL SCREEN.
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9346954
USE FULL SCREEN.
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9346991
@PolwskiPL
Run your games using FULL SCREEN. Stop using Windowed Mode.
HWMonitor has
  • (Current) Value,
  • Min and,
  • Max.
You can see if your CPU speed goes higher than 1400 MHz there.
Just run your game normally, and exit out of it...or ALT + Tab out.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9351327
  • 1.4Ghz is power saving clocks. It is normal at idle. If you see the same at load, it is not running at the correct speed.
  • CPU usage won't be 100% unless you use all 4 cores. For games, that depends on the game. A game maxing out 2 cores will show 50% CPU usage, and the two idle cores can do nothing to improve performance.
  • Builtin temp sensors in FX chips are useless at low temperatures/laod. You can see any random low number while idle. Under load the readings become more reliable. You can always use the socket sensor, which is typically a little higher than the builtin sensor (it is one of the motherboard's temps in HWmonitor).
  • Task manager in Windows 10 is known to show wrong CPU data in some cases. I don't know if it's a task manager issue and other programs will report correctly, or a Win 10 issue that prevents correct measurements. But I belive it's the former, i.e., you can trust HWmonitor.
  • In your last screenshot, you show 100% utilization in all cores with clocks at 1.4, which means that your problem lies with the CPU running at the wrong clocks. You need to double-check your BIOS settings, make sure no OC option remains. Safer route would be to load BIOS defaults, then change CPU-unrelated things you may have changed again.
  • If after doing that the problem persists, it could be CPU throttling. If not temperatures (doesn't seem to be the case), it could be caused by problems with power delivery from the motherboard to the CPU.
https://linustechtips.com/topic/736031-low-cpu-speed/#findComment-9351405
