SO my wholeeeee F@#@ing family is using the internet i cant do anytign about it
tried getting a a 3g-4g plan for my phone and using it!!!!
but the service is poop
so i want to know a way i can play overwatch WITHOUT 2000 PING evrytime :(
is controlling the bandwidth the solution?
please help!
Thanks
https://linustechtips.com/topic/735913-fing-ping-help-plzzzz/
Get better internet, or use Ethernet.
https://linustechtips.com/topic/735913-fing-ping-help-plzzzz/#findComment-9342335
A good router might help. They are expensive BUT they can prioritize your gaming session so your ping stays low and stable even if the connection gets completely saturated by your family.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/735913-fing-ping-help-plzzzz/#findComment-9342361
A "good router" wont help if he has crap internet speeds... no difference at all.
https://linustechtips.com/topic/735913-fing-ping-help-plzzzz/#findComment-9342372
Ran into this problem when I got myself and my girlfriend a Netflix plan, our 17mb line just was not enough for her to be on Netflix streaming, and me to be on fps games and hoping for a good ping, in the end we went with a new broadband plan which starts on the 15th.
PC - NZXT H510 Elite, Ryzen 5600, 16GB DDR3200 2x8GB, EVGA 3070 FTW3 Ultra, Asus VG278HQ 165hz,
Mac - 1.4ghz i5, 4GB DDR3 1600mhz, Intel HD 5000.  x2
Endlessly wishing for a BBQ in space.
https://linustechtips.com/topic/735913-fing-ping-help-plzzzz/#findComment-9342399
Well yea true but then there would be issues all the time regardless of the load.
Also, for online gaming you don't need a fast connection, you need a stable one.
If you have like a 4mbps connection that's solid AF it's perfectly possible to have a good gaming experience while having a 100mbps connection that's all over the place is not going to give you a good experience at all.
When i'm playing online it's usually a constant stream between 10 and 50 KB/s which is nothing even if you only have 4mbps or whatever.
https://linustechtips.com/topic/735913-fing-ping-help-plzzzz/#findComment-9342668
